Snip from http://www.novak-adapt.com/knowledge/t18_t19.htm
"Jeep T18
Jeep released 12 known versions of the T18 transmissions from 1966 and 1984, with the greatest variations being in input shaft configurations and gearing. The battle of working with these is compounded if you did not actually witness the transmission's removal from the donor vehicle.
Generally, most CJ T18's from 1972 to 1975 had the close-ratio, fitted with a front adapter plate in cast iron to the AMC bellhousing. These transmissions had the narrow ratio gearing (4.02:1 first gear). These 1972-1975 Jeep CJ T18's adapt to GM Engines with our #1415 kit.
1976 was a crossover year for the Jeep CJ T18, featuring either the 4.02 or 6:32 first gear and no front adapter as previously. Both these and all CJ T18's through 1979 had the shortest of the Jeep input shafts, measuring 7.43" of stickout.
All Jeep CJ's from 1977 to 1979 had wide-ratio T18 with the 6.32:1 first gear. No front adapter plate is present on these models. 1976-1979 T18 transmissions can be adapted to GM V6 or V8 by use of a T18 adapter kit that we manufacture, kit #1879. In 1979, the Jeep T18 underwent minor internal changes that affect the rebuild components used."
More T18 info here http://www.jeeptech.com/trans/t18.html
