donald wrotecould a broken timing chain cause my motor not to turn over? Brand new battery and it acts like there is no power to turn it over like way to much compression.
donald wrotemotor was not rebuilt any time within the past yyear or so since i have had it. The thing is if I pull start it the jeep will fire up but wont stay running if i dont flutter the gas. What if it jumped time will it cause the thing to act like its seized up?
What Engine? IIRC, most AMC engines use Motorcraft starters. They get weak with age like anything else.
Sounds like you have a bad starter combined with other gremlins that are giving you fits. #-o
I would start with some basic maintanence like check :idea: the plugs, compression, ign. timing and carb. Even something as simple as a plugged fuel filter will give you some serious problems.
More info could go a long way to a more accurate diagnosis.
