jeepsr4ever;128537 wroteCheck and verify your dont have a bad serial cable from PC to control head. It could also be a com port driver issue verify that in your ocntrol pane/system/hardware/hardware profiles. check to see if you have any conflicts.
I will give those a try soon
jeepsr4ever;128537 wroteIt is also possible however highly unlikely that the Ubob is bad in the control head. With the test button pressed in do you get the UP,DOWN and ARC OK lit up in Mach 3?
Yes, it was doing that in the test mode
jeepsr4ever;128538 wroteWhat post are you using as well is it the MP1000? If not change it to the MP1000. Remember always cut counterclockside it is the way the air swirls in that plasma cutter and will give you your best cut.
Using post MP1000THC. Is there a difference between MP1000 and MP1000THC? Not sure if there is even just a MP1000 but I will look next time I have the garage computer online.
I do have cut counterclockwise checked in Sheetcam
