The 360 in my CJ.
Edelbrock cam and Performer manifold
291-C heads, ported/polished, roller rockers
Bone stock bottom end with nearly 150K on it, new rings and bearings at about 80K. Burns less than a quart of oil between changes.
Running a T-18/Dana 300 with 4.27 gears.
I'm running a Howell 2BBl TBI system, I think it's rated in the 540? CFM range. I'm really quite happy with it. It ran about $1250 to my door, came with everything except air filter and fuel lines. They say you can run the factory lines (5/16 feed, 1/4 return), but they suggest 3/8 feed, 5/16 return. Except for a couple of bad O2 sensors (probably my fault, they don't like being splashed with cold water when hot) it's been flawless for 9 years. If you're set on a 4BBL TBI, they can modify their kit to use the Holley TBI.
www.howell-efi.com
