Is there a reason for not running these?
Prothane Mounts
This is what I'm running and I know they are the same dimension as the stock rubber mounts. An added bonus for 1/2 the price. As for "bomb proof" I've been rock crawling, mud bogging and trailriding for 6 years and the mounts still look new. (I'm also running the Prothane trans mount)
From the picture I have in my head, it seems that even if you get the geometry corrected, you could still be exceeding the u-joint angularity. iirc 23* total.... Damn CRS #-o
What does the geometry on your front driveshaft look like? What would happen to the front geometry if you took the shims out of the trans mount and moved the fan shroud?
I'm thinking more that you should contact MORE and start squeeking. Kinda BS to sell a part as "farctory replacement" and they start moving things around. Not to mention this is raising your center of gravity. Not very desireable.
