rbdesse I recently picked up a CJ T18 and Dana 20 combo from a 1975 CJ. However, the transmission slide gear (sometimes called a bull gear maybe) was not included. Where can I get a replacement gear, and what holds the gear onto the T18 output shaft? Is there a bolt or a snap ring? I need the fastener too. Does someone have a picture that illustrates the gear and how it is attached? Can someone shed some light on this topic for me? Also, where can I order the gear and associated part numbers? Anyone have a picture of one of these? Thanks.
tufcj The gear should still be available new. It's held on with a thick flat washer and a nylock nut. The output shaft in the T-18 is threaded. There's also a cast iron adapter about 1" thick on the back of the trans. http://www.jeepfan.com/tech/jeeptech/transmission-factory-t18.htm Bob tufcj
rbdesse o.k. I have looked for the parts, but I can not find them. Who is selling new T-18 to Dana 20 bull gear, washer and nylock nut.
tufcj Try Mile High Jeep Rebuilders 1-888-3-Mile-Hi or (303) 629-0378 They should have it both new and used. You might also try Novak - http://www.novak-adapt.com or Advance Adapters - http://www.advanceadapters.com Bob tufcj
