Well I have finally got everything assembled and I'm loving having this in my garage.
I had a friend put together the laptop for me, It is a Dell Inspiron 600m, that is now 1.5 gig.
Upon some Research I found out in order to get the laptop to communicate from the db25 port properly I had to update the ACPI driver to "Standard PC"
Now I do have some troubles with my setup.
NOTE: I am no computer expert by any means.
I cannot get the laptop to communicate with my gantry kit. Even when I trip the height limit switch the M3 home does not come on in Mach 3( I do have the license installed)
I converted a file I have made to G code with sheet cam and have run it through Mach 3 with no success.(no movement from the gantry)
Here is a list of what I have troubleshot so far:
I have checked the db25 cable and it is not a crossover cable.
I have also gone through the setup instructions 4-5 times and double checked everything.(maybe im missing something simple?)
(my only difference was the notation in my setup disc to set output #3 to port 1 pin 1)
Here are some screen shots I took of the Engine Config.
I'm looking forward to any tips to get me headed in the right direction.
Owen
