fifesjeep wroteNice... those oiling mods, did they run a belt driven oil pump, or something that had a little more volume?
Does anybody make 4 bolt caps for AMC's?
What's up with those freeze plugs on the side of the block? Are those the quick fix expanding plugs or is that something else.
Not sure yet, I have been in contact with the owner of Traco but he was at a customers shop when I called....said he had another in his shop he was freshening up right now with the number 444 heads and to call back but life took over and aint got back with him.
If there is any interest I will post what I find out.
Heads are a weird piece....dogleg casting numbers...but square exhaust ports and an xtra set of head bolt holes along the bottom row.
Block is drilled and tapped for them.
Also the valve centerline is supposed to be .045 farter apart than "normal" heads, but I have not measured that yet.
