I picked this up a while back and have decided on using a different intake. It has the AM part number on it behind the carb. It has a stainless filler tube installed, and the intake baffle on the bottom, and comes with a throttle cable bracket. It has had some previous repairs done to it, by Bulltear (according to the seller), to repair a crack by the stat (TIG or MIG welded), larger 3/8" bolts at the t-stat hsg, and some carb studs drilled out (were busted off). It has also been modified for mounting onto the earlier heads. See pics.
Asking $285
