Old Rugged Crosser
I understand that the Ford Torus fan and shroud work well for cooling on a stock CJ-5 radiator. Is that true and does anyone have part numbers or id #'s for both? Is it on a relay system? :-|
Thanks. :sa: :sa: :sa:
dan58
The taurus fan is AWESOME. You definitely need a relay. Search my posts here on the subject. Also search pirate. There's a TON of info on years to buy and how to set them up. I run Tyco relays from waytekwire.com
There are 2 "flavors". The one you want has 3 wires (2 speed), the one with only 2 wires is a single speed. You will need a relay and heavy wire, as the high speed draws something like 40 amps.
