These machines are not setup to take machining forces. The main issue with machining forces are acceleration and the angle of the force. Some mfgs will advertise a CNC plasma/CNC router but to do one well means you will not do the other well. Take DTHC for instance if you have a DTHC controlled Z axis you cannot route with it. But if you dont have DTHC you can do some routing but the system must be setup for it meaning larger/wider gear racks and slowing down acceleration on the motors...ect.
