People talk about it, people allude to it but no one ever seems to post the specifics. heres what has worked for me in pretty hot central valley CA temps 100+ in the summer
For $269.76 this combo keeps a warmed 401 reasonably cool in the summer.
Engine fan:
For engine fans that fit the stock shroud and suck lots of air.
- early 1970s - late 1970s Cadillac eldorado and others running 472s and 500's came with an 18" in diameter and 3-1/4" high pitch 7 blade fan
- also there is the 1981-1986 Cadillac with the 4.1L v8 it is 7 blade an 18 inches in diameter also with similar pitch right at 3" -3-1/8" and moves a lot of air. It is unique in that it as a reverse bend on the top of the blades easy to spot.
I picked up one of each for $5 a piece from pick and pull so $10 total they both seem to pull the same amount of air. pretty incredible difference. I ended up running the old el dorado fan because it was the second one i installed. Its moving a TON of air at idle now. I was going to install an electric fan. now i am not going to bother
Fan Clutch:
For the fan clutch I used a Hayden Severe duty fan clutch #2797 (buick with the diesel in the early 80's on some models like napa i had to notch the holes just a smidge to clear the bolts into the water pump but on a summit model i didn't, it was slotted deeper with universal slots). $48.79 from my local napa
For Shroud:
Stock CJ7 V8 shroud (stock no cost)
For Radiator:
For an aluminium bolt in radiator i so far have only found 1 that is really a bolt in dont change anything else option. Everything else is cross flow and requires a different shroud and radiator hoses which is fine but i didnt want to spend booko bucks and change too much at once.
Go to ebay type in "3 row aluminium jeep radiator" up will pop 20 adds for a down flow design radiator made by champion radiators. it bolts in, it fits and it cools better than the extreme 4 core radiator i got from extreme radiators. I paid $139+ $30 shipping it has 3 rows of 5/8" cores. a little less than the 2 1" cores of many of the cross flow radiators but it seems to be doing the job so far. I would like to some day later find a radiator with a 1" taller core and dual 1" tubes but thats splitting hairs when you look at what this el cheapo aluminium radiator costs compared to other options.
For a thermostat:
Combined with a 180 mr gasket or robert shaw high flow thermostat $14.21
For coolant:
I run 30% dextron synthetic coolant and 70% Distilled water with 1 bottle of water wetter $32.87
Water pump:
Flow cooler water pump $89.95 (i already had one since my old water pump puked i did not include this in total price since most guys i know have em already on their jeeps)
Few details on the jeep. CJ 7 mildly warmed 401, t18 D300 4.5" spring lift, 35's, 8274 winch and winch plate in front, 1" body lift.
I have a 1" body lift which put the stock 7 blade 17" fan right close to the shroud. To clear a bigger fan and to help with geometry when lifting the tranny I moved the MORE motor mounts up and that created ample room clear the 18" fan in stock shroud. Since i was going for a flat belly pan with my clocked dana 300 things needed to be shifted little any ways i re=drilled the more mounts 7/8" up and 3/8" for ward sliding the motor slightly ahead helped with valve cover clearance at the fire wall, moving it up allows you to continue using the stock radiator shroud. I only re drilled one hole, lifted the motor up slid two bolts in (one from each side) and then proceeded to drill out the other 5 holes. you will only be able to use 5 bolts the 6th hole is too close and wont clear a nut. i reused the factory frame cross bar on the lower holes. also much over 7/8" will not give you enough material to bolt to on the bottom 2 or 3 holes. FYI My flat belly pan is actually 5/8" below my frame but that is fine for what i wanted. I would not move it any further forward you will have shroud fan contact issues.
Tests so far:
In my garage with no air flow at 94 outside degrees and inside 95+ degrees with the jeep running for 30+ minutes or longer heating up the garage, front of the jeep facing the rear wall and 2' away from the wall. the jeep at idle does not get past 195-200 degrees idling and being rev'd for an hour at a time dialing in the idling characteristics of the TBI it still did not climb over 200, sustained 2000-2500 rpm in the garage for 10+ minutes it saw 210 then crept back to 200. it used to clear 220-230 no problems idling and at highway speeds used to hoover at 215-220. driving around in 95 degree weather never saw over 205 even on the highway around on city street maintains 195-200
As a side note:
I also changed to a high zinc full synthetic motor oil 20/50 and found i did shed another 5+ degrees in engine temps at highway speeds and it looks like i may have dropped some temps in lower situations also not much but noticeable. I run a 20/50 around here even in my fresh motor summer time we regularly see 90-100+ days on the trail and around town. with 10/30 or 15/40 my idle oil pressure drops down to 12-15 psi at 200 + degrees.
I have nickle timing cover, mid plate, HRC gears valley oil bypass line and small cam bearing holes with 7.5 qt oil pan. engine at 200-220 degrees maintains 20-22 psi at 600 rpm with dino oil, with the synthetic 23-25 psi at 600 at 1200 rpm+ it jumps to 55-60 psi no matter what.
Update:
Air flow wise under the hood i decided to cut in and add a few louvers. temp wise it hasn't changed much but it cant be hurting you can really feel the air coming out now.
[/url]
