tuf045
having problems with stepper motor direction on the gantry. ie the x axis direction if diffrent to the slaved a axis so the gantry instead of going straight trys the turn around .
I think that the problem is in the software mach3 but what do i have to change to get i right? in the ports and pins section?
Go to ports and pins (motor outputs) and click the "Dir low active" for A axis to make it spin reverse.
tuf045
ok will do. thank you!
How is everything running we havent heard from you in a month.
