juggernaught wroteOne last question......with a locker (or posi), installed in the front axle, It would seem that even if you disengage the front drive shaft (via a twin stick set-up), you would still get the "binding" associated with a "locked" diff. as you turn the steering wheel in a tight circle, because the diff. is still "locked".
The only way I can see there not being this increased "binding", would be because there is no power/torque being applied to the front axle. Am I thinking straight?
I presently have a posi. up front and would like to replace it some day with a locker. My main reason for installing a twin stick set-up would be the advantage of keeping my hubs engaged while being able to shift in and out of four wheel drive. But, I want to be sure that when I diengage the front axle that It will feel like I am driving an "open" diff. with no steering "pull". Please enlighten me.
I have a liconln locker in the rear and have run a few different setups up front.
I started with a spool and steering was horrible whether the front was engaged or not. I have read some who have had success running a locker in the rear and spool up front. I have not tried this so I can't comment.
Next I ran a Lockright. Steering was great. The locker had a bad habit of unlocking when you didn't want it to and locking back in when it shouldn't. Unit may have been defective but I was not happy with it.
I now run a Detroit and wonder how I went so long without it. Steering does not make any difference 4WD or 2WD. I'm spooled in the rear and that is noticable. (pushes bad) When the wallet allows, a Detroit will go in the rear.
My cousin runs Detroits front and rear in his CJ7 on 35s. (stock axles D30/AMC20) 2WD or 4WD you'd never know the lockers are in there. He can drive circles around me.
For a DD running Detroits, make sure the front hubs are disengaged on the street. Saves wear and tear.
Hope that helps....
