Lotta stuff going on here, I love it :t:
TufCJ and FifesJeep are both gearhead mechanics and good at what they do. If you’re going to push the speed limit, the SS valves and rollers will work well for that application. If you’re just going to the red line occasionally, put the money into a 3* valve job and port and polish the heads - you'll get more 'bang for your buck' than rollers (Harmon, Crane, Comp ... ) and with the 8600 or 8601, your red line is still over 5grand on the tach. What axle ratio are you going with? Where are you building engine performance at? [Has a lot to do with the rest of the trucks performance.]
I've got the Summit cam, but went with msalaba's option on the professional build on them from a local race shop. They measured valves, spring matched the weights and provided the correct length push rods to meet the rod-angle geometry in my 360 heads using the OEM style rockers. The little bit of friction (HP) saved with rollers wasn't in my requirement$ $heet :?:
I'm also running some Mad Dog Racing parts and haven't had any worries with the double roller timing setup. Got Bulltear's nickle case cover and oil pump setup along with the matched cam gears and spiffy ALT relocation bracket.
And I too would like to see the PS relocation idea hit the street, but I bought the BT serpentine setup, just haven't had a chance to install it yet (Rich, when you coming over?? :-| ). And I still have a set of nitride coated headers that have been under my desk at work for a year or so!! Guess when I get the slush box rebuilt and ready to install, I'll change my headers too 111!!!
Anyway, I just got back from 3 months in Japan and have a full list of 'gotta do first' items (that's the 'honey do' list we all dread) - including about 10 cords of wood that needs split and off my yard!!! :shock:
A total quality product requires a comprehensive idea on what the end-product should look and act like. Building a 10K RPM capable motor is spendy and wasteful unless you're going for 8's or 9's in the 1/4. If you’re looking at a capable wheeler and DD, the engine needs to work with the axles and tire diameters to operate in a suitable and efficient (road) or power (off-road) RPM range. Unless it's a purpose built machine, there will be compromises, and only you know what you can afford - both in $$$ and capability.
There are a slew of RPM vs Speed calculators on the web.
Or if math hurts your head like it does mine, check the chart <HERE> :?
In my CJ, @ 2650 (+/-) RPM, w/4.56 lockers and 35's, I'm pushing 63-65 MPH by GPS. So the chart is close at 2625 RPM and 60 MPH. :mrgreen:
'Rat
