Those that don't pay close attention to the accuracy of pierce height...buy more consumables, especially nozzles (tips) for their plasma torches!
There, as I mentioned above, are different methods used on different machines for finding the surface of the plate. This function of the height control system is often referred to as IHS (initial height sensing). The Bulltear machines use a limit switch and a floating head, essentially the torch indexes down, contacting the plate, which floats the movable potion of the z axis assembly, tripping the limit switch. This type of unit needs to be set-up in the software to account for the hysteresis (backlash) in the limit switch, ensuring that the torch will retract accurately to the pierce height.
Other IHS methods used on plasma cutting machines for initial height sensing:
Floating Head...mentioned above.
Ohmic Contact. This method uses electrical contact sensing between the shield (front most component on a shielded torch) and the plate. This method works quite well on clean surfaces, and is probably the most accurate method of finding the surface of the plate, however does not work on primed, painted, masked or rusted surfaces, and also does not work in submerged (underwater cutting) applications.
Stall Force Sense This method uses adjustable stall force sensing by measuring z axis motor stall or current (depending on the design of the circuitry) to sense contact with the plate. This process works well although on thin plate it tends to deflect the plate, rendering the pierce height inaccurately. Works very well on thicknesses over about 12 ga, and on all surface conditions.
Inductive sensing This method uses inductive probes that sense the plate when close. Typically only used on very high current (400 to 1000 Amp) high end industrial systems where robustness is most important and accuracy is least important!
Optical or sonar sensing These methods are occasionally used...but have only had limited reliability due to surface conditions ans well as shop conditions (smoke, fumes, etc.)
Jim
