tufcj wroteGo with a high volume oil pump, not high pressure. Also replace the drive rod between the dizzy and pump. I've seen older ones shear from metal fatigue. It also doesn't hurt to braze the pickup to the pump, where it attaches is above oil level, and it can suck air if it isn't tight.
good idea about the pickup. i said the same thing about the pump too, high volume. moves more oil. never thought about the drive rod.
