PumpkinCrusher
I have a recently rebuilt AMC 360(less 1000 miles) since the rebuild that has started to leak oil from the front of the engine. Oil is leaking near the front of the engine near the oil filter and pump. Prior to the leak starting, I added a york ac compressor and new alternator brackets. As you know, it meant loosening up the front water pump,oil pump housing to get the new bracket and bolts in. Did I upset something to cause this leak? I've since replace the oil filter, sending unit and made sure the lower oil pump bolts were tight. Any thoughts? Thanks John
The oil does pump from the front cover into the block thru a passage on that side. Did you change bolts? It's possible one is too long and bottoming out in the hole before the cover is tight. Just something to think about.
tarior
Is the PCV hooked up?
PumpkinCrusher
Yes it's hooked up. Not getting any leaking at the top of the engine. I did use a bastardized PVC valve to get a cleaner installation since my engine lacked the manifold grommet. Could having an incorrectly size valve cause it to leak somewhere else on the engine?
tarior
One of the purposes of the PCV is to prevent pressure from building in the crankcase. If you have pressure building up in there, you'll get more leaks.
