are you serious...........i cant find one anywhere, everybody is closed.....i 2nd day shipped the transformer to have it here. if i knew i needed one i would have ordered one. do you have a part number for the resistor i need so i can next day it from them.
"2. The current transformer for arc ok is hooked up like this. You may need to loosen the power cable coming in to your 101. One leg of the 220 line goes through the center of the current transformer. The current transformer utilizes a resistor on top between terminals and it will come with one. The resistor has long metal legs you wrap around the current transformer and on each end you also include one lead to the arc ok terminals on the DTHC card. These terminals on your card will have little screws fro tightening."
is there anything else that i need to get this machine going.
