before you spend any more money with howell consider doing your own chips. I was really unhappy after 2 years of mailing chips back recording data and spending gobs of money on shipping and poor performance with my howell system, which for a 401 specific system howel uses the 85 lbs/hr injectors on the holley 670 cfm tb which is bigger than the gm 350 tb that they typically use on 360s (which is 500 cfm). Anyways the point is consider the craig moates system, and have him do the soldering for you its $25 for him to solder up your computer.
start here:
http://www.binderplanet.com/forums/showthread.php?t=47254
It made a world of difference for me i go for a drive, i record data on my lap top. i come home i run the dos based smoothing program which takes the data you recorded and the original .bin file and raises or lowers the numbers from the .bin file to reflect what the recorded data said was off. it spits out a new bin file that you can then veiw in a program like tuner cats (which i really like for its simplicity) where you can smooth out the fuel map if there are any peaks or valleys and you can correct areas that the smoothing program did not catch or adjust. burn a new chip all in less than 2 minutes and go for another drive if you want.
My build was:
I am running a 401 .030 over
a set of 9:1 forged bulltear pistons
lunati 64501
Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/220
Gross Valve Lift (Int/Exh): .484/.507
LSA/ICL: 112/108
Performer intake
HEI dist
mild ported 502 heads
roller rockers
8 qt oil pan
arp bolts and studs
ported out cast iron manifolds
dual 2.5" exhaust.
If i didnt already have it i probably would have run an Engle cam. similar cam timing events and Engle goes alot more agressive on the lift #'s for similar durations. The cam is a little small for the motor on the top end a little but it is a very torqie motor. Very strong runner with the fuel injection i have been able to dial down and maintain an idle of 250-300 rpm not perfectly smooth but it will do it. I keep my idle at 500-525 and it is very smooth.
I went a little crazy and used all ARP bolts in this motor with studs ont he bottom end, it wasnt necessary but why leave anything to chance. I would not run the edelbrock heads i think they are great but for what i did with my motor the cast iron heads were plenty. maybe i could picked up another 20 hp and 20 ft/lbs but for the $$$ it wasnt worth it
i suspect a lower total hp number due to a fuel injection issue above 4500 rpm i suffer a minor fuel supplly starvation. injectors are too small or fuel pump can't keep up. i knew i was right at the limits of things on the fuel system. I could up fuel pressure in the TB and get more fuel from the 85 lb/hr injectors since they are rated at 15 psi an up ticking of the fuel pressure would increase the flow of the injectors but i am happy with the spray pattern and low rpm performance too big of injectors and too much fuel can begin to slosh around. Point is the 670 TBI is pretty good fit on this motor.
On a chassis dyno rear wheel numbers it put down the 292 hp @ 4900 rpm 389 ft/lbs @ 3500 rpm it had a similar 351 ft/lbs at 2000 rpm and carried numbers at and above 354 ft/lbs all the way to 4000 rpm. red line is 5500 rpm and it spins hard on the street to 4500-5000.
As you can see the above are rearwheel numbers
assuming 10-12% parasitic drivetrain loss it should be in that 320-330 hp 430-440 ft/lbs range. the shop that put it on the rollers called it out as 331 hp and 443 ft/lbs.
It definately feels like a 330 hp motor if i didnt have the rear wheel numbers i would have sworn it to be a 350 hp competitor btu the torque covers my butt
Some cams to look at:
Comp Cams
Magnum grind
270H
.479/.479 270/270 adv 224/224 dur @ .050 110/106
Extreme energy
.477/.484 256/268 adv 212/218 dur @ .050 110/106
.493/.500 262/270 adv 218/224 dur @ .050 110/106
Lunati
.484/.507 256/262 adv 213/220 dur @ .050 112/108
.507/.527 262/268 adv 220/226 dur @ .050 112/108
Engle
.489/.489 254/254 adv 209/209 dur @ .050 112
.501/.501 260/260 adv 214/214 dur @ .050 112
.538/.538 272/272 adv 224/224 dur @ .050 110
I'll tell you what in a CJ turning 35's on dana 44's with alloy shafts a T18 and a 4:1 D300 this is a very snappy motor and i think i am near the limits of what those poor axles can take. I was hoping for idlability not max power on this motor. and i built it with that in mind and i am VERY happy with the performance. I am not going to say this is the combo for you but i will tell you with everything dialed int eh way it is this motor and this rig are now alot of fun on and off road. and it sounds like a thumper too. There was plenty more i could have probably squeezed out of this motor but i wanted a reliable low rpm high torque motor and i think i found my combo that works for me.
Look at Donwags build if you want to see a well done grunt motor with edelbrock heads i think his numbers were similar to mine but he had the 256ex and had edelbrock heads which have better port velocities. his motor maybe could have taken advantage of the heads and thier potential with a slightly larger cam with similar duration numbers but higher lift numbers and pulled some more power out of there. the 256 performed well for him but i think it was on the small end of the choice spectrum. not saying mine is much bigger. but doing this build required that i use what i had in an effort to keep costs down. my numbers werent as high as his but i am nipping at his heals with a pretty stout runner.
