mika01 wroteThat was my main concern belt slipage with the main PS belt in the end turning two pumps. Does yours slip?
I do have the option of running an electric pump from a snow plow application. But for Elliot's kit price I was willing to give it a try
It used to be worse before I actually had FSJ pump in place. My plow was adapted from a factory dodge setup, that pump died, I put one on from another FSJ with pulley and put the back housing/tank on from the dodge pump. My brackets ended up with a piece of thread rod in one spot to keep everything tight. I really only get a little slippage now when things get wet, but I also run a locked fan clutch since I had over heating on the road with the blade on, and the alt is still in stock location so it slips some too. My long term plan is to go to the higher amp GM alt, use Bulltear's high mount kit for it, and go with an electric fan, going serp was just another thought to go with this, I think I would be good with just doing the upgrades to the alt and fan.
