I looked at the Rancho catalog, and they must be RS9012's with just shy of 14" of travel. I have Rancho 2" bumpstops in the front and 3" in the rear. The do work differently, since they contact the spring, and not the axle like factory, due to the SOA. MY CJ only has about 4-5" of compression, and can just about max the shock on droop. I positioned the mounts with compression and droop in mind. I also use a mounting pin faced front/rear, so the shock twists on the bolt as the axle articulates. A 2-tab or side/side mount causes the shock to twist the bushing, and can limit travel.
This is the kind of flex I get.
