ironman_gq wroteyou can measure compression height yourself and find skirt clearance in the manual if they are cast. if they're forged you need a little more cause they expand more but a good machine shop should be able to give you a number.
compression height is from the center of the wrist pin bore to the top of the piston at its edge not to the top of the dome if it has one.
I am aware they could be measured, but I do not have them in my hands, hence the need for published figures. They are forged, but were the old "square window" forgings that don't use much more clearance than cast. Memory wants to say a minimum of .0015". So, if anybody has an old catalog, those figures, and the dish volume if it was published, would be very helpful.
Thanks!!
