tufcj wroteI'd go to a performer manifold and a 600-650 CFM carb with Vacuum secondaries (NO double pumpers). You might be running out of both fuel and air at higher loads or WOT.
I am unfortunately in an enhanced smog test area of Kalifornia. This means tested on a dyno, and non approved aftermarket parts (eddy manifold and carb) are a no-no. Judging by the vac readings Im sure Im running out of carb around 3500rpm, I just wanted a confirmation.
tufcj wrote
Have you ever run a sniff test under load (on a dyno) to see if you're running lean? Lean mixtures will sap the power quicker than rich mixtures, and can do internal damage too.
The first engine was run on a dyno with this carb and jetted accordingly. So its in the ballpark. If I go more than a step or two up, the exhaust starts to stink.
tufcj wrote
You said you had to slow the curve to stop pinging. That would indicate to me you're running lean.
Yes. I had originally had full advance in around 2500rpm, and it was pinging on hot days under load. Full advance comes in around 3200-3500 now and although I may sense a slight drop in power its nothing Id consider worrying about. Now that the temps around here have cooled off, I could probably get away with putting it back. I could also go a step or two up in jetting but it doesnt seem to gain anything more than stink, and I am due for another test in January.
Im more concerned right now with the lack of overall power. With everything that went into this engine I really thought it would get up and go much better than it is. The cam is a lower rpm (under 4500rpm) cam and if vac readings are a reliable way to check for carb efficiency, then I should be good under 3500rpm.
I have heard that people that have gone to TBI with a 500cfm TB havnt noticed any power gain, so mabye I expect too much. If it really does just need more carb I may be out of luck.
With the small carb, would a longer duration cam help ?
Could I get away with a 260-270 duration cam and not affect the low rpm power ?
k.
