pablorg wroteI am also interested to know if the 268H is an improvement over the performer plus. Anybody?
there is more to it than just sticking a cam in
what rpm range do you desire, where do you wan thte power to come on. you say a stock 360 so low compression is going to hurt bottom end with too big a cam. what is the torque converter stall?
talk to engle, lunati or reed they all seem to be pretty well versed in the AMC motors.
MC posted a 360 400 hp recipe you should check that out, lots of good tech. not you dont need screw in studs with the 268 but you will have to check and possibly cut your valve guides down, i doubt stock heads can clear i know my last two sets needed to be cut down to clear anything more than .480 lift. the one prior to that didnt need any cutting and cleared .507 lift.
There are several great 360 build threads with engines similarly setup to yours and with posted results here be it est hp numbers, seat of the pants or real world numbers to help you make a decission.
i wouldnt run the edelbrock performer cam there are better options out there for a motor larger than a 304 cubic inch.
