1970 and later part numbers I keep handy:
AMC 304/360/401 Stainless intake bolt kit ARP # 414-2001
AMC 304/360 Rod bolts ARP kit ARP #114-6001
AMC 401 Rod bolts ARP kit ARP #114-6002
AMC 360/401 Head Bolts kit ARP # 114-3602
What’s not listed in ARP’s book:
AMC 304/360/401 bridged heads mill down .375 use guide plates and roller rocker studs. early heads with small pushrod holes require no milling nor any guide plates. For roller rocker studs etc if you want 7/16" on both ends use ARP # 135-7101. For the smaller 3/8" studs and RR's which are ok at .500 or less lift and lower spring pressures they will have 7/16 on the head side and 3/8" on top use ARP # 134-7104. - *** Remember to use hardened pushrods. some setups need .100 longer pushrods.
http://www.arp-bolts.com/pages/products/pages/rock_arm/links/app_verfy.html
For the Mains:
AMC 360/401 2 Bolt main 351 Clevland stud kit ARP # 154-5404
AMC 360/401 2 bolt main Big Block Chevy bolt kit ARP # 135-5002
Flywheel bolts since all too often guys are swapping an automatic to a stick and wanting the bolts here’s a starting point
½ x 20 thread my old set # is no longer listed but ARP 200-2804 are UHL 1.00” and close enough to get the job done. mine are 1.25" long and stick out a little too much on the back side of the crank
Clutch pressure plate bolts - GM 292-502 applications ARP # 190-2201
