sprink669
I have the serp system and was wondering what everyone was using as far as an alternator? I bought a Powermaster alt. and the shaft is too large (40 thousands) difference. I would like to know what everyone is using. I tried the pulley on 2 of the donor motors that I have and it did not fit either one? Thanks!
One is a 5/8 (.625) keyway. The other is a .669 alternator pulley. Because of the mix and matching that so many jeeps and AMC cars have over the years you could have either. 5/9 keyway is the most common. Now that you have a powermaster are the cooling fins sticking out past where the shaft meets the center of the cooling fins? There are 4 different alternator styles out there.
sprink669
thanks, I received the right pulley today!
J
MC,
I got my SERP but it's been in the shop waiting attention. Time I haven't had.
Just thought I'd let you know :oops:
cj5doc
I also have the same problem with my power master alternator. I believe I need the .669 alternator pulley and yes my cooling fins stickout past where the shaft meets the center of the cooling fins. offset approx .115
cj5doc wroteI also have the same problem with my power master alternator. I believe I need the .669 alternator pulley and yes my cooling fins stickout past where the shaft meets the center of the cooling fins. offset approx .115
Send it in for exchange
