hi boys,
well, here I am once again knocking my head against the wall. The rebuild is 5 years old, with maybe 5000 miles on it 3000 of which were put this year. It's not a daily driver so...
Anyway it's your typical mild build,
-.30 over
-edelbrock intake
-Summit SUM-8600 cam http://www.summitracing.com/parts/SUM-8600/
-Howell TBI
-MSD distributor (blue-heavy silver spring, 21 deg max advance)
-MSD Offroad ignition
-TFI coil
-.045 plugs
-bulltear timing cover and oil pump
-15w40 non-synth
-4 core rad (rebuilt after engine)
-160F thermostat
-17'' Derale fan (puller)
-oil cooler
I noticed that the advance had a good effect on engine heat so I've been playing with the advance to control detonation (pinging) and trying to control the heat. Right now it's around 5 deg with vacuum off, vac adds 10 for 15 total at idle.
Currently, idling it will keep heating up and not cool down, I need to go about 40mph at light throttle to get it to at least stay around 195. Or turn the heater on. Idling the temps will just keep climbing.
We also think I'm consuming oil cause I keep having to top it off but can't see any serious leaks. There is a light accumulation of oil in the breather pan. Would some type of blowby let heat travel into the engine and be the source of all this? Bad rings? Unseated rings?
