juggernaught wroteThanks chris.......When you say .020 off the "DECK" you are talking about the top of the block. Correct?
DECK corresponds with the top of the block, ie: Zero DECK.... Pistons sits @ .000" when measure from where the heads meet the block, DECK Height... the distance from the center of the journals to the surface where the heads bolt to the block...
juggernaught wroteWith my valves installed, the edge of my intake valve sits about .020 above the newly surfaced head. How does this compare with a head that has not been surfaced? Can anybody tell me?
About stock distance... that's almost what my 502 heads measure.
juggernaught wroteThis is all a pretty stock set up with the exception of 9.0/1 pistons and the fact that the heads have been shaved.
What casting numbes are those heads? You can have the heads CC'd and then you'll be able to better judge/determine roughly how much has been milled... It's not the most scientific or proper way but it'll put you in the ball park.
juggernaught wroteIs ther any one who can give me an idea of how many thousandths these heads can be milled before I need to worry about interference? What would be the best way to go about checking that clearance if necessary?
Take some clay/puddy etc put it on your piston bolt the head down without the gasket, install the pushrods, rockers etc and slowly rotate the motor by hand, do two full turns break it back down, what i do is carefully cut the puddy/clay in half with a new razor and i carefully lift/remove one side and I use my dial calipers to measure the compressed thickness... (It's good to try it on a few cylinders)... Once you get that number add the thickness of the headgasket and that will give you a relatively close ball-park figure.
