fifesjeep
Here are what is on this cam... Can you figure out who/what/specs etc?
Behind the front (forward most bearing) is 3180 and 259 casted into the cam...
A little further down in-between the lobes (working towards the rear) are these... CWC... I 5.... CU... C36... D36...
I did a quick measure on a couple of lobes and these were my measurements... (side to side) = 2.454"... (top to bottom) = 2.718"... for a difference of .264"... These measurements are slightly off due to me holding the cam and having Clevite77 lube all over... :!: I'm sure it is supposed to be .259 as the casting deisplays behind the front bearing...
That's all I have folks...
Clean it, bench it and use a dial indicator :-)
I have a used stock cam with 114K on it if you want :razz: 8)
Is it a Crower?
Edelbrock
fifesjeep
I honestly don't know... hehehe I've been researching this cam... but with no luck I decided to toss it on here to see if some of these cam guys would know..... :oops:
juggernaught
The numbers are very similar to a cam I just pulled out of my rebuilt 360. Did you look at the end of the cam very closely to see if it is stamped. Mine was "cal cam". I know mine was a cheap reground cam. Hope this helps.
fifesjeep
The very end had something... i didn't look too closely as it was barely visible...
