AMC NP208 (23 Spline Input w/32 spline outputs) = $150 (shifts great/smooth)
AMC TH400 to D300 adapter (27 spline to 23 spline) the adapter is 4 1/4" long = $375 (new is $538.20)
AMC TH400 to 13-39 adapter = $50
TH350 to NP203 adapter = $50
3" Purple Hornies = $100 obo
Dynomax 1 5/8" to 3" Collectors = $100 (comes with custom 1/8" copper gaskets (these gaskets are Used but will probably out live the vehicle)
Never Used RCI 16 gallon Fuel Cell with rollover valve = $125
Poison Spyder full width Ouboard Kit for CJ's from 76-86 = $325 (It's still attached to the frame... will sell both (frame and outboard kit) for $550.
D60 Rear w/4.10 gears = $150
D61 Rear w/3.07 gears = $100
Pro's : Great ground clearance as the differential is almost flat on the bottom, 3.5" tubes, Extra thick Housing, Spline count can easily be converted to 35 or greater...
Con's: In stock form, Poor gear selection... But, With a series 3 carrier, thick gears and a spacer this axle can run all of the D60 internals... (I DON'T HAVE THE TIME OR THE PATIENCE TO PLAY AROUND WITH THIS)
Dana 60 35 spline spiders = $60
FF 14 Bolt Disk brake brackets w/spacers, bolts etc = $60
FF D60 disk brake brackets = $60
(4) H1 12 bolt Beadlocks = $175
NP203 reduction Box w/main-shaft = $75
4" drop pitman arm = $50 (Never been used)
89 YJ Tub w/CJ Tailgate has two gas fills (driverside and passenger side), Tub has No rust, two piece custom dash (Something Simple)... 6 point cage from PO goes with it = $450 obo
CJ Frame No rust New Body mounts comes with steering gear unti = $300 obo (Poison spyder outboard kit is attached will separate if not wanted)
(2) Hunsaker Baja Seats with new covers (These are the plastic ones = $125
(2) Used 5-point harnesses = $50 obo
CJ Windshield frame = $75 (Like New)
CJ Hood = $75 (Good shape)
CJ Grill = $75 (In good shape)
CJ Fenders = $50 (Not perfect but overall not bad)
These items will be on the chopping block in a few months...
Waggy D44 front w/2.73 gears :🙂 has the Tie Rod flip already done to it = $175
Ford disk brake LP HD flat top 44 w/4.10 gears and large hubs etc = $250 (Putting it back together was using it as a parts axle... should have rotors on it shortly as well as new balljoints/u-joints... and some paint).
AMC 20 w/2.73 gears :🙂 = $100
Q78's with about 1/2 tread = $250
Aluminum 6 lug 15" rims = $250
- Will sell the tires and rims together for $450...
AMC 360 Runs/great oil pressure, Bored .030, New bearings, cam, lifters, timing set, rockers etc... = $150...
I'm willing to work with ya if you need something... If you have something to trade... whatcha got?
Rich
