I want to say that these are the standard +.030" replacement pistons... I know this is a shot in the dark but, do these look familar to anybody?
I haven't dropped the pan yet (tomorrow I will) to look at the under-side of the pistons...
This 360 came out of the 82 Waggy. It had great oil pressure and Compression Readings... this motor was/is clean inside so... I have decided to do a quick/cheap build on it... The cylinders still have the cross-pattern, the rockers/springs, valve tips, lifters and cam all look new...
My plans for this motor are simple... Shave the heads .034" , toss on an Edelbrock intake, comp cams RV cam kit or the 270 magnum kit, 1.6:1 Roller rockers, Holley 670, some headers and the simple ignition up-grades... I'm keeping this one real simple and cheap...
Thanks.
