Hey guys,
I have a newer reman 360 less then 2000 miles on it. Just recently I developed an annoying oil leak near the oil pump. I can't pin point where it is coming from so I can fix it. It drips enough to concern me. It appears that it only leaks while the engine is running but I can't find the leak at idle or at 2000+ RPM while parked in the barn. Has anyone had a similar problem?
Pan bolts tight
Oil filter new
5 quarts new oil
Oil pressure at idle 15-20 lbs/ cruising speed 60 lbs
Lower pump bolts tight
Oil slightly weeps from the front of the pan
After a short drive I find oil residue all over the filter, oil pump, bottom of the alternator.
