I did go with a high steer and the thing to remember is to keep the drag link as close to parallel to the tie-rod as you can. If your just pulling and not driving, bump steer won't be much of an issue. If you do drive it the 'rake' will look different, and you'll need to make sure castor and camber are close to stock or you'll wander all over the road.
I just put a set of Reider Racing (Deadnbear) knuckles on the CJ. They are 3/8" taller and have 4 bolts for the high steer arms (my arms only use 3 though). Plus they allow for a straight 1/4-20 zerk to grease the upper ball joint =D>
Click pic for larger image ...
. Passenger side
. Drivers side
And yes, the Haynes is open to the torq specs page :mrgreen:
