Steve_Obertanec Here it is guys. After a lot of work they are finally here. Due to be released 5/29/09... Wiseco Pro Tru pistons. 4 part numbers. Available @ Summit, Jegs, Etc... -------------------------------------------------------------------------------- For Jobber pricing contact: Vic Ellinger Technical Sales Direct: 1-800-321-1364 Ext. 3016 Fax: 440-951-6606 -------------------------------------------------------------------------------- Specs: Hastings rings 1/16 1/16 3/16 Plasma Moly rings Xylan anti friction skirt coatings 2618 alloy forged piston 250HP Nitrous Capable/Turbo usage (All part numbers) 360 Dish (.930 wrist pins) PT114H3 .030 over -21cc Reverse Dome $646.61 Jobber PT114H45 .045 over -21cc Reverse Dome $646.61 Jobber .190" deck thickness .280" Top Land .160" Second Land 360 Flat Top (.930 wrist pins) PT115H3 .030 over Flat Top $568.21 Jobber PT115H45 .045 over Flat Top $568.21 Jobber .200" deck thickness .280" Top Land .160" Second 401 Reverse Dome (1.000" wrist pins) PT116H3 .030 over -27cc Reverse Dome $646.61 Jobber .190" deck thickness .280" Top Land .160" Second 401 Flat Top PT0117H3 .030 over FT $568.21 Jobber .190 deck thickness .280" Top Land .160" Second --------------------------------------------------------------------------------
jeepsr4ever That is really cool Wiseco is doing these but have you checked out these. http://www.bulltear.com/catalog/product_info.php?products_id=231
jeepsr4ever We actually make H13 tools steel pins in the correct size for AMC V8's. You need to have a 1.001 for the 390 and 401 or the pin will walk and destroy the motor and for the 290,304,343 and 360 you need a .931 or the same will happen. Now this doesnt mean you cant run a full floating pin but that means either new rods or bushing your stock rods and in some cases it isnt good to take out the material. I see you are lisitng the 360 in a .930 and a 401 piston in a 1.000 size. I commend them for stepping up but I hope they did their homework. :idea:
