rollbar
What poundage are U all running for your AMC-360? 3 core CJ radiator.
Thanks,
Jim
Keep it in the 14-16 PSI range. Every 1 psi raises the boiling point about 3 degrees. Pure water boils at 212 with 0 pressure, with a 15 psi cap it will go to about 257. The boiling point of a 50/50 antifreeze mix is even higher.
rollbar
Thanks Bob, I guess I'll go w/a 15lb cap.
