The pump only produces pressure between the pump and carb. You can add something like this inline: http://www.jegs.com/i/Mr.+Gasket/720/1564/10002/-1 Pressure at the carb should be in the 5-7 PSI range.
The suction side, between the tank and pump really can't be reliably measured since the pump only moves liquid, not air (which is what causes vapor lock). If you're trying to fix a vapor lock problem, the best solution would be a low pressure (> 5PSI) "pusher" pump mounted near the tank. Fuel under pressure is much less prone to vapor lock that fuel under vacuum.
I ran a Carter 6906 on my CJ with good results, but finally just eliminated the mechanical pump for an electric mounted at the tank. I went to an in-tank pump when I went to EFI.
