HotJimmy;124005 wroteI've been fighting fueling problems with band aids for too long. This Jeep is a 1982 CJ7 street rig with a well built 401 and TH400.
I initially had problems with vapor locking. I wrapped the fender well exits and it got better, but never good until I replaced the cheap napa electric pump with a nice Holley red label. Even still, on hot days it would occasionally vapor lock.
I need to replace the stock fuel sending unit and while doing this I'm finally rerouting my fuel lines to a better location. But I want to put an in tank fuel pump while the tank is dropped as well.
Has anyone ever seen or made a conversion for an in tank pump on a stock CJ tank? Carbed engine, so low pressure preferably. A high psi pump would work too with a return type psi regulator.
Like I said, this is my street jeep not my crawler, so I want to retain the stock tank/ location and avoid a fuel cell.
I just did one in my 82 CJ7 Limited I put a 4.0 and in tank pump.
I used the stock sending unit, some fuel injection rated hose and a pump from an 87-91 YJ Wrangler w/4 cylinder TBI (this pump should work fine for your application as well.
