ironman_gq wrotesticking relief valve (big nut with a spring and piston behind it) will cause intermittent no pressure
Can you just unscrew and clean it out? I'm having fluctuating oil pressure. It's start's off at 60 when cold, holds about 40 for a bit, then drops to 20 when hot, sometimes it comes back up.
