dirtyoffroad
I am running a 670 Holley projection on the 69 390 in my CJ,runs pretty hot,borderline overheating.It didnt do this when carburated,I've messed with the settings,trying to richen it up.should I just go back to a four barrel?
Pretty typical!! Try to make it as rich as possible and see if that changes. You may also have to adjust your timing or quite possibly have a thermostat/clutch fan/water pump issue.
dirtyoffroad
I addressed all the coolant parts,the 670 TBI has only 2 injectors,I like not flooding out on inclines and off cambers but like I said,didnt seem to run this hot when I was carburated
does it run much stronger? more power=more heat. you could try changing the timing too maybe pull a few degrees out of it
tarior
Lean condition can cause overheating. So can improper timing.
