msalaba I am in the process of gettng my heads shaved. I assume the pushrod length will also need to be adjusted. So, if I have 0.060" milled, would I need 0.060 shorter pushrods? 79 360 heads, stock bridged rocker setup.
jeepsr4ever .024 will get you .5 in compression and .060 will give you 11-12 to 1! 7.800" is the std length pushrod on a 72-91 head
