Pat,
Here is a quick run-down with your knuckle. Don't mind the pics, some are Fuzzy. :oops:
Here is a Picture of the second Seized stud. Man, I tried like He!! to get it out... but, I only ended up breaking my vice #-o
Stud has been cut and drilled. After this pic I stepped up the bits until there was barely any material remaining and then I was able to use a scribe to pull the rest of the stud out. 111!!!
Stud has been removed and drilled to size. Notice on the second hole how the material has been lifted, you can see the witness ring. :shock:
Another pic of the hole only difference is that it's chamfered.
Hole has been tapped and the insert installed. The second hole has been drilled and chamfered.
Second hole has been tapped and is ready for the Keensert.
Both Keenserts have been installed and NOW you're ready to rock. (When is the working party meeting up) 8)
A top picture of the Keenserts installed. Notice the witness ring is gone :t:
So, there it is Pat... She's ready and waiting for your approval...
Rich
