I've been reading some of the recent posts on fuel injection systems for a 401.
I want to convert to TBI and I am trying to select which system to install. Right now I'm looking at the Holley Commander 950.
http://www.holley.com/950-22S.asp
I'm having trouble finding the right distributor. I'd like an ECM controlled distributor.
Holley has a GM style distributor to go with their TBI system but it is expensive (approx $400). And I don't know for sure if I can put this into my 401.
http://www.holley.com/890-160.asp
Engine specs...
Camshaft information:
Gross cam lift: .310
Rockers: Stock 401 rockers @ 1.6 = total lift of .496.
Cam Duration is 220 degrees at .050. Howards lobe profile #4756 (whatever that means).
Compression ratio is 9.8 to 1 (Speed Pro pistons).
Stock AMC 401 heads w/ dogleg exhaust ports.
Stock exhaust manifolds (no headers).
Intake is Edelbrock Performer #2131 with a straight bore vacuum secondary Holley.
Displacement
Bored .030 over stock.
Original Bore: 4.165
Actual Bore: 4.195
Stoke: 3.68
Displacement: 406.9 CI / 6.6 liter
Bore/Stroke Ratio: 1.1399
Ignition
The ignition system uses the original distributor which was converted with a Pertronix Ignitor II kit. www.pertronix.com/ and one of the Pertronix Flame-Thrower high voltage coils. (Don't remember which one.)
Any advice or recommendations?
