(I posted this on ifsja with little response. Hopefully we can figure this out here...)
Its a long story.
http://www.ifsja.org/forums/vb/showthread.php?t=72976
Heres the short...
Had hot running/overheating issues forever. Tried new radiators, clutches, water pumps, AutoMeter temp gauge, you name it. Got the NAPA block test kit, had exhaust in coolant. Pulled heads, had them checked, they checked out ok (but I wasnt convinced), used new FelPro gaskets and a new set of ARP bolts. Still had same issues.
Figured it was a cracked block so I pulled the old engine, got a known good core from a generous member on IFSJA, and built another engine.
I have 170 miles on this engine the temp gauge has started doing the same things. I went out today and (using a lever-vent cap) got all the "air" out of the radiator. I squeezed the top hose until there were no bubbles in the overflow.
Started it up with the lever open and let it get to operating temp. Once up to temp for a few minutes and varying the rpm's, I squeezed the hose and got bubbles in the overflow.
…I let it cool and got the NAPA block checker out…
Ive got bubbles bad. Fluid goes yellow/green in one squeeze of the bulb.
There is exhaust in the coolant.
I do have one question based on a part I reused from the old engine. The intake manifold.
Is there any way for exhaust to pass (by way of a crack or flaw) from the exhaust crossover/egr passages in the stock 2bbl intake manifold into the cooling system ?
I have an older stock 4bbl manifold I looked at, and it just doesn’t look possible… But you never know… Doesn’t hurt to ask…
k.
