ironman_gq wroteshould be the fuel is constantly flowing through the line and through the bypass and back to the tank so its not sitting in the lines absorbing heat for to long
Ok, thank you. I was just thinking 1-3/4" might be cutting it close.
Now, as for the return line (I replaced all the lines w/SS & the frame was bare when I picked it up so I went w/the bigger feed line only), I do not have one. Running the V8 & the 600 D-Pumper should I get one? I notice a lot of guys not running one. I am going to run a 20 gallon polly tank.
Thanks,
