OK, the prep is done for the U-POL Raptor spray in bedliner. I have to wash it tomorrow morning and then tape it off/spray it.
Below are some pics of the POR-15 applied.
Bulkhead
Backside of windshield hinges
Windshield mounting locations
Front cowl. This will stay since it is behind the dash etc.
Drivers side door jamb just above the joint
Bulkhead joint and side walls done
Bulkhead installed
Now here is where I sanded the tub w/180 grit and hand sanded/buffed the tub w/a red Scotch pad per the U-POL instructions. I added the 180 grit, wanted the stuff to stick as good as it can.
Tomorrow I wash the tub, air dry it, tape it off and spray 🙂
Taping tub off for Raptor bed-liner spray
Taping off the bolt holes etc.
Shooting the Raptor. IMO, a lot better then the roll on liner for the ease of application/looks
First coat shot and out in the sun to bake
Having fun
Touch up out in the sun so I could see better
Finished, removing tape
Jr removing some tape
Jr removing the tape off the foot of the roll bar
Tub complete
Tub complete, sorry about the camera angle
OD color contrast on how it will look when completed
Ok I'm tired and I am very please w/this product. Prep was 180 grit and then followed up by a red Scotch pad. I wanted it really scuffed due to some of the POR-15 used and old paint on top of paint. Way to easy w/the spray on. I had the compressor @ 120psi and regulated the spray @ the gun. I did some test shots w/just air w/the compressor set @ 50psi to get the feel, then raised the compressor and adjusted @ the gun. Worked out well and when I changed bottles I just unhooked the air line to keep the consistency for the next bottle. After the first coat & stuck the gun in some lacquer thinner and shot until the gun was clean. Waited an hour while it bakes in the sun & shot the last coat w/the main object concentrating on the bed since it will take the most abuse. So, how does it look? I'm sure it will pop when the OD gets on there. 🙂
Fenders & hood sanded
POR-15 on lightly rusted areas
POR-15 on battery tray, hood support, vacuum can, jack plate & fender supports
Since I am doing OD & black I think the black accents under the hood would look good.
