kiwi wroteTry this for size, I have a bone stock 78-401 ($100 for the whole wagoneer) I put a used turbo off a 97 powerstroke ford on the thing, piped the exhaust from the 401 manifolds to the twin inlets on the turbo. Modified a used Holley, built a carb hat from an old kitchen pot I got from the thrift store (didn't keep the handle) welded in an exhaust 90 & hooked it up to the turbo with a piece of hose & a cheap ebay BOV. The BOV keeps the boost to 11lb up to 5500rpm, beyond that it's too small & crushed a float in the carb. Just need to double up the BOV's, cheaper & easier than a waste gate. The boost comes on strong at 1500rpm & I have a stock converter in the trans. It's a blast to drive & it's cheap.
Cost:-
$100 = 401 engine. (I got the whole wagoneer for that).
$100 = Junkyard turbo 97 Powerstroke. (I got the mount base, the two exhaust rings & plates, the turbo front pipe & v clamp & the short intake pipe & v clamp that feeds the eng.
$29 = blow off valve. (ebay)
$100= Exhaust U bends, oil lines & fittings & misc.
$0.25c= Pot. (steel, even had flowers on it)
That's pretty much it, I dont know what hp it makes but in a 1700lb street rod, shittin n gittin comes to mind & I've never had a passenger that hasn't come out with a few holy $#!:<'s.
I'm sure it would work on a late smog 360 but would come on a little later. If any one wants to give it a shot they will not be dissapointed. A low cost AMC to kick some Big 3 butt.
Kiwi Sid.
Kiwi,
I have a few issues with what you wrote. A BOV (Blow off Valve) only activates when the throttle plate closes and the boost pressure bounces off it back towards the turbo and causes compressor surge.
What you just wrote is a load of crap (in regards to the function of a BOV). A BOV IS NOT A WASTEGATE AND YOU CANNOT REGULATE BOOST PRESSURE ON THE COMPRESSOR SIDE WITH A BOV. A BOV IS SIMPLY THERE TO PREVENT COMPRESSOR SURGE.
What you need is a WASTEGATE ... WHICH OPENS UP A PORT EITHER IN THE MANIFOLD OR IN THE TURBO TO BYPASS THE COMPRESSOR TURBINE THUS CAUSING THE EXHAUST GASES TO BYPASS THE TURBO AND LOWERING BOOST PRESSURE AND REGULATING IT TO YOUR DEFINED MAX.
Sorry if I come off like an ass but that kind of information is what blows motors up. I have pushed over 20 Lbs on a 3bar MAP sensor and custom tuning ... realize that fifesjeep is only looking to push moderate boost (5 to 7 lbs) as a 360 has a cast crank that will only deal with so much and the volumetric efficiency of a turbo will make all the difference. I don't want anyone to blow up their hard work is all.
I think you may have some vocabulary mixed up and some definitions wrong and that may be the cause of the mixup. Kiwi I always admired your turbo build and its what made me want to boost my rig so please don't take my post as me diggin on you. I ripped my foot open so I'm in a lotta pain today so i'm a bit grumpy.
#-o #-o
-Dave
