Labatttman
I am building a '79 amc 360 to replace my 304 in my '77 cj7. This is what I have so far edl.performer rpm heads pt#60119, crane gold rockers, performer intake, cheep headers with cherry bombs, al6 ignition, msd pro bilet distributer, edl. performer plus cam pt#2132, holly 670 truck avenger, nickle plated timing cover and oil filter adapter, high flow water pump, and all the bolts and gaskets. For the bottom half I got a 79 360 bored 60 over. It's got less than 1000 miles on it. The crosshatching is clear and I gauged the cylinder; no egg shapping. The rebuild was done with stock hight pistons. I have not disassembled the rotating assembly to inspect the bearings. My Question is: what will my compression ratio be and what should I do to get at least 9.5:1 and also should I change the new bearings or rings from stock style. this is not a high rpm build
