tufcj wroteMost emissions era OEM timing sets are machined about 4 degrees retarded for better emissions. On the Edelbrock sets, 0 is truly straight up.
You do realize the lobe separation angle and lobe centerline are 2 different things? If you look at the spec card on the Edlebrock 2132, the LSA is 110, the centerline is 105.
Yes I do realise that c/l and lsa are different.
I had this Engle ground to my spec which was 112"lsa and 112*icl.
It really is out.
Ive spent the better part of the day out there checking the cam. Ive checked the intake and exhaust events at .006" and at .050" and with the timing set installed in the 4* retarded position, its still 3* advanced.
Its now at 109icl and 115ecl.
109+115=224/2=112lsa.
Either the cam was ground 7* advanced or the timing set is off. Chris at Engle told me that it would be ground 1* advanced to make up for chain stretch, which would still leave it at 6* out.
I can live with it 3* advanced, but Id like to know why its so far out.
k.
