What Distributor is it ?
Ones from eBay have been known to have "issues".
Not mating properly with the Timing Cover, Drive Gear, and Oil Pump drive.
STOP and do not proceed if source of Distributor and drive gear is not known.
What Distributor Drive gear was installed on the Distributor shaft ?
Best to use the original AMC Distributor Drive Gear from the original Distributor shaft
that was allready ran with and mated to the original AMC Distributor Gear that was on the Camshaft.
Many have destroyed Drive Gears from using aftermarket Distributors or Mis-Matched Gears.
Munched drive gears mean metal shavings all through the new engine, not a good thing.
Oil Zinc ZDDP Additive
Yes, Rotella-T has ZDDP additive, but not as much as it used to.
Local GM dealer sales something called "EOS" in a 1 pint bottle for ~$12.
Strongly recommend getting a pint and adding it to the oil for break-in.
For insurance 1/4 pint EOS can also be added with each oil change.
BullTear also offers for sale at a reasonable price it's own custom blend AMC HD Oil which contains sufficient amounts of ZDDP.
Oil Filter
Many find the AC Delco PF24 Oil filter to be better than others at preventing drain-back,
quickly building pressure on start-up, and almost immediately turning off the Oil Pressure light.
Pre-Oiling, Distributor Install, & Initial Timing
Minimize the amount of turning over of engine before first start-up.
Remove Valve Covers during pre-oiling.
Pre-oil using a power drill and preferably a BullTear Pre-Oiling Tool, or something other.
Do not push down too hard on pre-oiling tool to prevent scoring oil pump cover with oil pump gears.
Pre-Oil until Oil is seen coming from top of pushrods onto rockers.
Oil may appear only at some of the rockers when pre-oiling.
Rotate engine 90 deg by hand, run drill, oil should appear on other rockers.
Repeat this process until oil discharges from all pushrods onto the rockers.
By hand, turn over engine to TDC on Compression on #1 Cylinder.
While Dizzy is still sperate from the engine Install the Dizzy Cap.
Useing tape and a marker, make a vertical mark on the lower housing in line
with the #1 cylinder post position on the distributor cap, remove cap.
Now, being sure the Dizzy to Timing Cover Gasket is in place, install the Dizzy into the Timing Cover.
Position Rotor Button approx 2 cap post positions counter clockwise from the #1 Cyl tape mark.
Rotor button will rotate upon dizzy insertion into the engine and should end up aligned with #1 cyl tape mark.
Once installed rotate housig slightly Counter Clockwise so that Rotor Button is located
about 5 degrees CCW from the #1 Cap Post tape mark.
This should set initial timing at about 10 deg advanced.
Have a timing light already hooked up and ready to go before first start-up.
Have Dizzy clamp snug enough to hold dizzy but still allow adjustment.
Initial Advance at idle is somewaht incidental and insignificant.
Total sum of Initial & Mechanical Advance is what matters.
With Vacuum Advance disconnected, Total Advance should be 38-40 deg with mech adv all in.
Is the amount of total mech adv and at what rpm know for the new dizzy ?
Mechanical Advance springs and weights should allow a max of 24 deg and be all in before 3000 rpm.
Use of a Dial-Back Timing light makes this process much easier.
Break-In Run
Upon first start-up use light to check and set timing to maybe 25-30 deg advanced at 2000 rpm.
DO NOT let the engine idle long during break-in run or for first few hundred miles.
More or less continuously vary the rpm between 2000 to 3500 rpm during break-in run.
Vacuum Gauge attached to Manifold vacuum is a good idea.
Vacuum gauge should be fairly rock steady while running.
Leave Vacuum Advance disconnected during break-in run to allow the 38-40 deg total advance to be checked.
Oil Pressure
Would say on a cold fresh engine should see 65 psi max at 2000 rpm.
Keep an eye out for pressure spikes and watch the filter for ballooning.
Stock Pressure Relief Plunger and Spring should prevent pressure from exceeding 65 psi.
If the Oil Pressure Relief Plunger happens to stick, pressure can spike and ballon the filter.
If Oil Pump was packed with Vaseline it can can collect behind the plunger and cause it to stick.
Vaseline can also somewhat clog the Filter under oil gets hot enough to melt it.
Any plans to video the event and post it on YouTube ?
:t:
